Seems some of my posts are not showing up here. I posted the following last night to see if any of you know that this means.
When I run the generator the LED on the EMS switch lights up, so power is getting to that switch. However, still no power to trailer. When it's switched to the ON position, I get the following codes: 128, OA, 60H, E2, PE2
Just spoke with Oliver. Here's what I learned. Those codes are saying either the Neutral Ground plug is faulty, or the surge protector is faulty, or the connection to the bypass switch is faulty. He recommended having an RV Tech check it out after trying a new Neutral Ground Plug.
Duane
