Jheim
    917
    Legacy Elite
Jheim's Achievements
Rookie (2/14)
8
  1. So I left the leveler down with a small amount of pressure on it. This way if the jack ever shifted the leveler will be right there to catch it before it goes through my fiberglass!
  2. Thank you I agree! I would not put it on the fiberglass. I ended up putting it on the metal.
  3. Hi so I want to take pressure off of the levelers and use jack stands. Question is where is the jack point exactly? Is it at the sticker that says, "jack point"? Or can I put it on the beam? I just don't want to break the weld on the beam but it looks like it would hold much safer.
  4. Thank you Roger and I will definitely look for those YouTube videos
  5. Yes cleaning the window track was the first thing I did. It hasn't rained hard since then but there are some places that the caulking seems a little sketchy. I'm figuring better to be on the safe side and reapply silicone or whatever I'm supposed to use.
  6. So mineral spirits won't hurt the gel coat?
  7. The larger window at the dinette table on my Oliver le1 leaked recently when it rained really hard. I see some of the caulking on the roof or around the window could be the problem. I'm thinking if I just replace whatever looks questionable should hopefully fix the problem.
  8. Hi does anyone have any suggestions on what the best way would be to remove old caulk on my 2021 Oliver LE 1? Also any suggestions on what type of cualk to use? Thank you
  9. Hi I have a 2021 EL The outside rubber gasket around the window is getting spotted discoloring. Is there a way to clean it?
