DBL-R
    99
    2015
    Legacy Elite
DBL-R's Achievements
Apprentice (3/14)
8
  1. Hello everyone, I bought a new converter (PD4045CSV) and installed it this afternoon. Now everything is working as they should and batteries are charging. this was an easy do-it myself project. When I removed the old converter it appears as though a resistor (R24) came unsoldered (see photo). I wonder if I were to resolver the resistor in place, if I would then have an operable spare. Next project will be to replace the shocks and the repack the wheel bears and we will be ready to hit the road. Ron
  2. Thank you
  3. Thank you for the advice, I will certainly look at them. Ron
  4. Thank you
  5. Thank you
  6. Thank you
  7. Everything appears to be wired correctly and the fuses are good. I spoke with OTT and other than the batteries loosing voltage, there is no way for me to test it. The suggested taking it to a service center and having them do diagnostics. Since it is in the garage, on a battery tender, and not winterized I will do that this spring. Since it is new to us, it will be worth a piece of mind to have it check out. While we are at is does anyone know the make and model number for the shocks? I want to replace those and all I could find was the Monroe 555001, not sure if that is correct or not. I am waiting on a call back from the parts department. Thank you all for you assistance. Ron
  8. Thank you, I am using a Deltran battery tender, it’s a smart charger and it has not fully charged the batteries (yet). My panel does not match what was in the manual!
  9. Thank you Mike I think the issue is that when plugged into shore power it doesn’t charge the batteries and if there is no sun to charge them they will die. Ron
  10. Thank you everyone, this forum is awesome support
  11. They are now at 12.4 v and still chaarging, the batteries were replaced in December of 2023, with deep cell marine batteries. I still don’t know why it isn’t charging when on shore power and it lights and other items are only running off of the batteries.
  12. Great news! Overnight, the batteries charged and are now at 12.2 volts. Everything works as it should—lights, TV, stereo, and so on. It’s not connected to shore power. My new theory is that the 12-volt batteries supply power to all those items and charge properly when sunlight or solar power is available. When plugged into shore power, the 120-volt power will power the fridge, microwave, heater, and air conditioner. However, the other items continue to draw power from the 12-volt batteries and don’t switch over to the 120-volt power source and ultimately drain the batteries. Looking st the owner’s manual there should be 3-25 amp fuses, looking at the panel there are 2-30 amp fuses and one empty slot (see photo). Any thoughts? Thank you Ron
  13. I put the batteries on a battery tender we’ll see if that helps out. I also tried a second 30 amp 120 V circuit on the outside of the house that made no difference. I thought maybe my power cable was bad but when I plugged that into 120 V the microwave works, but all the lights are still very dim. That was just an update. Thank you for all your help. It’s time to get some rest. Good night.
  14. Geoff, the 30amp 120v circuits is brand new. The surge protector indicates that the circuit is good. Still getting battery on I can only assume since the trailer is in my garage. The solar wouldn’t charge the batteries. Since there are two batteries connected together if I put one of the batteries on a battery tender, will it charge both batteries?
  15. Hi Bill thank you, the TV is unplugged from power, not sure how I could unplug the stereo wi the out removing it. Where would I find the negative bus bar? sorry for the ignorance but the Oli is new to us. Ron
