Search the Community
Showing results for tags 'penguin ii'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • News & Announcements
    • General Announcements
  • Oliver Forums
    • Getting Started
    • Introduce Yourself
  • Oliver Campers
    • Oliversary Stories
    • Delivery Day Photos
    • Mechanical & Technical Tips
    • Ollie Modifications
    • Towing an Oliver
    • Service Talk
  • Oliver Camping
    • Campgrounds & Parks
    • Events & Rallies
    • Ollie Boondocking
    • Submit Your Story
  • Oliver Campfire
    • General Discussion
    • Oliver Blogs
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
About Me
Website
Found 1 result
  1. Issue: A/C Fan runs when mode set to furnace Models Impacted: Dometic Penguin II equipped Information: The on-board thermostat communicates with the Dometic Penguin II A/C unit and the A/C unit then communicates with the Furnace. When the mode is set to Furnace the A/C fan should not run if set to AUTO. If the fan speed is set to LOW or HIGH, this will cause the A/C unit fan to run with the Furnace as a means to distribute the inside air flow. If you are experiencing this issue, please ensure that the fan speed on the A/C is set to AUTO. Resolution: Normal Operation *If the A/C fan runs when set to Auto and mode is set to Furnace, then another issue exists and the Dometic A/C unit should be inspected by a Dometic certified technician.
