Jim and Frances Posted March 21, 2024 Posted March 21, 2024 I removed our bike rack factory installed 1.5" receiver and noticed some corrosion on the underside of the rack where the u-bolts/washer attach . Will be checking other fasteners / washers going through the aluminum members around the bumper/bike rack area and adding some thin delrin/acetal washers to put under the stainless washers and maybe adding a thin coat of Ultra Tef-Gel to the hole walls -OR- should I do something different? SE Texas | 2021 Elite II Twin Bed # 927 "Lucy" | 2019 F250 FX4 6.7
Jim and Chris Neuman Posted March 21, 2024 Posted March 21, 2024 Corrosion between dis-similar metal is common in the boating world. Very common to find severe corrosion between, say, a 6061 aluminum mast pad or hardware pedistal and a bronze halyard winch if the two are bolted directly together. A thin layer of plastic between the two virtually eliminates this problem, particularly if you use an anti-sieze on bolt (typically stainless) threads. I use lanolin anti-sieze commonly found in boating stores. My favorite barrier material is easy and cheap to make. Prepare a smooth surface with mold release wax, lay a section of a light fiberglass cloth (say an 8 oz) and saturate with a laminating epoxy such as West Systems or System Three. You now have a sheet of flexible barrier material which can be cut to size as needed. 1 2
Jason Foster Posted March 21, 2024 Posted March 21, 2024 6 hours ago, Jim and Frances said: I removed our bike rack factory installed 1.5" receiver and noticed some corrosion on the underside of the rack where the u-bolts/washer attach . Will be checking other fasteners / washers going through the aluminum members around the bumper/bike rack area and adding some thin delrin/acetal washers to put under the stainless washers and maybe adding a thin coat of Ultra Tef-Gel to the hole walls -OR- should I do something different? This is on my to-do list. 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
