Raspy Posted December 31, 2016 Posted December 31, 2016 Has anyone had to access the bathroom faucet connections or replace the flex hose for the shower? Seems there is no way to do this without installing a port on the front of the cabinet or in the closet. The 4" port used on the propane cover would be good, but exactly where to put it is tricky. What do they do at the factory to fix these? John "I only exaggerate enough to compensate for being taken with a grain of salt." LE2 #92 (sold), Black Series HQ19
Try2Relax Posted December 31, 2016 Posted December 31, 2016 The shelf unit below the sink is removable. Depending on whether you have a newer or older unit affects the ease at which this is accomplished. This is good for both the plumbing and accessing the wire run from the front of the trailer. You can find the info here 3 Randy One Life Live It Enjoyably 2017 F350 6.7L SRW CC LB 2015 Oliver Elite II Hull #69
