  • Director of Operations
Issue: A/C Fan runs when mode set to furnace
Models Impacted: Dometic Penguin II equipped
Information: The on-board thermostat communicates with the Dometic Penguin II A/C unit and the A/C unit then communicates with the Furnace. When the mode is set to Furnace the A/C fan should not run if set to AUTO. If the fan speed is set to LOW or HIGH, this will cause the A/C unit fan to run with the Furnace as a means to distribute the inside air flow. If you are experiencing this issue, please ensure that the fan speed on the A/C is set to AUTO.
Resolution: Normal Operation
*If the A/C fan runs when set to Auto and mode is set to Furnace, then another issue exists and the Dometic A/C unit should be inspected by a Dometic certified technician.
  • Thanks 7
Jason D. Essary
Oliver Travel Trailers, Inc.
228 Industrial Ave
Hohenwald, TN 38462
Phone: (888) 526-3978
Hours: Monday - Friday 8:00am - 5:00pm CST
CONFIDENTIALITY NOTICE: This email may contain confidential and privileged material for the sole use of the intended recipient(s). Any review, use, distri­bution or disclosure by others is strictly prohibited. If you have received this communication in error, please notify the sender immediately by email and delete the message and any file attachments from your computer.
