I was greasing and checking the Easy-Flex suspension at 6000 miles. The shackle nuts were fine, but several of the u-bolt nuts were a fraction loose, and two on the same bolt were 1/4turn loose. I checked these at 3000 and found the same situation, tho I can’t recall if the same nuts were loose both times.
These should be checked every 3000 miles until they no longer require tightening, then you could go to a longer interval.
  • Thanks 4
