Service Director Jason Essary Posted August 10, 2018 Service Director Share Posted August 10, 2018 Issue 1: Fan inoperative Issue 2: Fruit Flies or Gnats in toilet Models Impacted: All models delivered before 8/8/2018 Information: Nature's Head recommends using a 2-5 amp fuse for the composting toilet fan. Many models may have been produced with a 1 amp fuse in the converter for the fan and may result in it blowing. Fruit flies and/or Gnats may become a problem in the composting toilet gaining access via the top roof plumbing vent. Resolution 1: Replace the 1 amp fuse with a 5 amp fuse. You can use a 2, 3, or 4 amp fuse as well just as long as it is within Nature's Head recommended size of 2-5amps. Resolution 2: *Place a mesh screen, like the material used in the window screens, over the top plumbing vent pipe. You can also use products such as Diatomaceous Earth or Gnatrol as well. You would need to refer to the Nature's Head Compost Toilet manual for the recommended process for adding these products to your toilet. Please see attached manual. *By placing a mesh screen over the vent pipe you will need to periodically clean this to keep it from becoming clogged and causing a plumbing issue. Natures-Head-Composting-Toilet-Manual.pdf 8 ---------------- Jason D. Essary OLIVER SERVICE 228 Industrial Ave Hohenwald, TN 38462 Phone: (888) 526-3978 Hours: Monday - Friday 8:00am - 5:00pm CST CONFIDENTIALITY NOTICE: This email may contain confidential and privileged material for the sole use of the intended recipient(s). Any review, use, distribution or disclosure by others is strictly prohibited. If you have received this communication in error, please notify the sender immediately by email and delete the message and any file attachments from your computer. Login to Service Portal: https://support.olivertraveltrailers.com/portal/en/home Link to comment Share on other sites More sharing options...
