Wondering if any of you who have used the Tire Tracker TT-600 as a pressure monitoring system have found it necessary to use the signal booster?  I seem to lose signal after an hour or two of driving for some reason....
I responded to this in a PM to you, but maybe other folks would like to read this and comment.
Mine works great without the booster, tho I bought one just in case.
It may have to do with the length of your tow vehicle, extra steel panels (like the front wall of a pickup bed and the rear wall of the cab), a steel rear bumper, and perhaps dense cargo stored in back that might block the weak radio signals. My Land Cruiser 200 is fairly short (112 inch wheel base) with plastic rear bumper and perhaps I am on the edge of of losing the signal and just don’t know it.
The signals travel straight from low near the ground, so having a booster in your closet up very high would probably be very effective at beaming the radio waves straight at your cockpit.
Have you tried extending the antenna on the display? Mine is down all the time.
