Leaking
Wildflower
View Inventory
Check the third/top tail light. If you can't see a problem with the caulk, or feel water in the attic cabinet, you can check the light for leaks  by running duct tape around the edges, and either wait for rain, or spray it with a hose.
This area is probably the most common area I've heard of for leaks, over the years. The water can run down the cabinet, and around the window frame, making you think the window is leaking.
