  • Administrators
IMPORTANT TECHNICAL SERVICE BULLETIN
ISSUE
Potential Internal Battery BMS Damage
MODELS IMPACTED
2021 – 2022 Oliver Legacy Elite II models equipped with (3) Lithionics Lithium 130AH Batteries & Xantrex 3000W Inverter
INFORMATION
Oliver Travel Trailers was alerted that under certain conditions the Lithionics internal BMS could be damaged if the full load for inrush amperage to the inverter is loaded on a single battery.
RESOLUTION
Owners with impacted year models should follow the Lithionics approved method for the proper restart/reboot sequence of the batteries and inverter to ensure all batteries are ON before turning the inverter ON.
NOTE: The inverter is also a charger and when it powers up while connected to shore power this is utilizing the charger side. The above referenced potential condition exists only when the inverter side is turned ON.
PROPER RESTART/REBOOT SEQUENCE
If the inverter is OFF, drained or has entered (LBCO) Low Battery Cut Off and any or all of the batteries are OFF (no LED light on battery), then the following procedure should be followed:
1. ENSURE THAT THE INVERTER IS TURNED OFF
2. UNDER THE STREET SIDE BED ACCESS PANEL, SWITCH THE INVERTER CIRCUIT BREAKER TO THE OFF POSITION. PRESS THE RED BUTTON
Note: This will cause a communication issue for the inverter remote display and requires a proper restart sequence to ensure proper communication between the inverter and remote display. (Error 20)
3. TURN ALL BATTERIES ON
4. SWITCH INVERTER CIRCUIT BREAKER TO THE ON POSITION. PRESS THE LEG BACK INTO POSITION
5. TURN THE INVERTER ON AT THE INVERTER
6. VERIFY COMMUNICATION SOFTWARE HAS LOADED: U3 01 06
  A. PRESS THE UP/BATTERY BUTTON TO SCROLL THROUGH
7. TURN THE INVERTER OFF AT THE INVERTER
8. TURN THE INVERTER REMOTE DISPLAY ON
View a PDF version of this Technical Service Bulletin here
For questions or assistance please contact the Oliver Travel Trailers Service Department.
228 Industrial Ave, Hohenwald, TN 38462
Service Phone: 1-888-526-3978 | Email: service@olivertraveltrailers.com
Matt Duncan
Marketing Consultant, Oliver Travel Trailers
  • The title was changed to TSB Proper Lithionic Reboot Sequence
Guest
This topic is now closed to further replies.
