SNY SD UP Posted November 4, 2022 Posted November 4, 2022 I know what this, but was wondering if anyone else has seen this sub-assembly and has experience working on the component? B out Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed
Guest Posted November 4, 2022 Posted November 4, 2022 Looks like a burner, maybe for the Truma AquaGo hot water heater? No idea how to work on it...
SNY SD UP Posted November 5, 2022 Author Posted November 5, 2022 Yes, it is the Truma AquaGo Comfort WH "Burner Assy". We started getting a flash error code 1, "Flame not detected", about half-way thru our last trip. I talked to Truma, while on the road but we were not able to resolve, with just the things I could do over the phone. So I waited until we got back home to look at it closer. I brought the trailer to our closest Truma Auth Svc Center (in ND, 400 mi…) they talked to Truma Svc, and when removed the Burner Assy basically fell apart. There are 8 slats (what i will call them), the picture shows 3. I am not sure where the other 5 are, maybe still attached to something in the complete unit. I know we have hit some pot holes and have been on some washboard roads. We ran the tires at 80 psi (as delivered) for probably 7k miles until I found threads on lowering tire pressure. I lowered it to 65 psi for last years (10k mi) trip and then 50 psi for this summer’s trip of 16,000 miles. The trailer definitely runs smoother & softer, we found less evidence to shaking in the trailer while on the road. We will be purchasing a new Burner Assy from Truma and replace the damaged one. So the next question is, is this something that I should be able to repair (sounds like a remove & replace) myself or should I pay my non-local RV svc ctr to do it. Has anyone removed and replaced this sub-asy before? Asking for myself... Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed
