I was looking for a way to prevent a road bump from releasing the TV from its horizontal stowed position. I know some have put pieces of pool noodle between the TV and the underside of the "attic" cabinet, but I didn't like the way that pressed on the plastic back of the TV. I wanted something that would fit against the metal bracket instead. I came up with this:
It's a section of large pool noodle, slit lengthwise twice, with that section removed to make a large "C" shape. The "C" then clips around the bracket attached to the back of the TV and wedges between that bracket and the underside of the "attic" above. This way, all the pressure is on the metal mount, not on the TV, and it still prevents the mount from bouncing up and releasing on a rough road.
