Replacing co/propane monitor with new one due to several error messages. In the process I am guessing I blew a fuse.
So where is the fuse? In previous discussions regarding these monitor someone spoke of an inline fuse behind the monitor below the seat; not on my 2022.
So where and which fuse?
Thanks for any help.
It’s in that area where your inverter is under the steet side bed (front).
**Sold😞**
Thanks rich.dev.
Also received this from Mike at Oliver Service; more quality speedy customer service.
ELITE 2 MODELS
INLINE FUSES ARE LOCATED UNDER THE DRIVER SIDE BED ACCESS PANEL
mail?url=https%3A%2F%2Fsupport.olivertraveltrailers.com%2FgalleryDocuments%2Fedbsn6bd50c0abea233276c5d38e9af00fe1891cab478985ac578fbf0c79f5a0b65e3646ab927b090dd1fa6223397186eb62f%3Finline%3Dtrue&t=1698096750&ymreqid=2a5e4497-2202-b5b3-2207-3c001c015f00&sig=6_jWY6E8bJVv7lluDTe.nw--~D
