389
2018
Mingy's Achievements
0
Dexter Axle BULLETIN Reference # 1ZP9-ABC12-19
Mingy replied to BackofBeyond's topic in Mechanical & Technical Tips
FWIW I just got the recall message a few days ago. Hull #389. Got under it with my 1/2 inch wrench set to 60 ft - lbs. None of the bolts budged. A long extension and a u-joint were necessary for the bottom two bolts on each wheel. -
I have a 2007 F250 crew cab longbed with a V-10. 38 gallon gas tank gives me a highway range, with safety margin, of 300+ miles, on flatlands. No payload worries even though I tend to travel heavy. Handles well. More than adequate power and torque. 5R110 tranny is sound and has been reliable. The engine is reliable and basic maintenance is easy, parts are readily available. Highly recommend this set up based on my experience so far. Yes, I know a diesel has braking advantages, more power, better mileage. Also sharply increased up front costs, and it costs more to maintain. That difference, will pay for a lot of gas. I would like better brakes, though mine are more than adequate for my driving style and the trips that I have taken. But that's it.
26 ft trailer with a whole lot of weight in back
Mingy replied to John E Davies's topic in General Discussion
The ship, be sinking. And just how far can it sink? The sky's the limit. -
Thanks for all the information. As it turned out, I hadn't given the thermostat box itself enough time to cool down. I set the thermostat to 90 (heat) and the ambient temp of the trailer was 82 but when I shot the temp of the thermostat control itself it was over 90, it is not blown on directly by AC. Probably warm air inside the pantry too didn't help.
I'll try the fuse first - pull out, crimp socket, reinsert. No organic peas. Hell, no organic anything. But a blue ice flex pack should do the trick.
Greetings all, Every month I check all the systems in the Oliver. As usual, everything worked. The surge suppressor shut down my AC intermittently because the line voltage was 110, not unusual on a 100 degree Florida afternoon with everyone's AC cranked. But I was able to cool the interior into the low 80's to test the furnace, and nothing happened when the thermostat (furnace heat setting) was set to 90. The gas works fine - fridge is running on it. The water heater works fine. The blower for the furnace did not come on, nor did it fire. I pulled the furnace cover outside and all connections seemed tight and no trash was present. No apparent burned spots on the board. Now, am I unaware of some feature that requires a lower outside temperature for the furnace to work, or does this seem like a bug? Any help would be appreciated. Mingy
Craig, You will find that they are designed and built by intelligent life. Mingy
Making the decision to purchase an Oliver vs. Airstream
Mingy replied to Ken_Judy's topic in General Discussion
Only one way to work on that Sonic. With a match. -
Hey Ken and Judy! If you look at my profile, you will see that I named my Airstream "The Silver Sieve." If I wanted to design a TT to rot itself out, I couldn't do better than an Airstream. Replacing one axle and the AC? The nearest dealership wanted $5000.00. I told them that I wanted Sandra Bullock to call me "Big Daddy" but that wasn't going to happen either. It is somebody's hunting camp now and I am towing an Ollie. No regrets. -
I have both the Honda and the Yamaha. I can sling the Yamaha around where I want it but the Honda is a different story, would need help going from ground to truck or trailer. I keep it on a utility cart and that makes it easy to get into my truck. Used to powerlift, and my girlfriend is a bodybuilder, but she's almost maxed out with one side of the Honda and probably couldn't lower it slowly into the basket on the Oliver to check the fit. Wish I had gotten the Micro Air. Then the Yamaha plus other goodies would fit in the basket, and the Yamaha would run the AC easily. You live and learn.
I have both. Just not an EZ start because I was penny wise and pound foolish so I need the Honda to run the AC w/o hiccups. Installing the Micro Air will void the warranty I think. I have a locking mount for the Honda in my truck, so if I wanted to camp/atv ride it would be necessary to put the atv in my truck and the generator in the trailer tray. After backing out the atv the genset could be locked down in my truck. I can lift the Honda but can't position it in the box to check the fit. My preliminary measurements tell me it will be close as can be.
Greetings All, Does anyone know if an EU 3000I by Honda will fit in the tongue box without mods? Its weight is about the max allowable in the tongue box, say about 150 lbs. Mingy
Ford’s new 7.3 liter big block gas engine
Mingy replied to John E Davies's topic in Towing an Oliver
I have a V-10 6.8 L, 5R-110 tranny. Thirsty engine but robust. I wonder how the new 7.3 will compare? 288 hp, 4000 rpm, and 424 lb ft at 3000 rpm for a V-10. OK, maybe it will beat those numbers. Then the question is durability. 10 cylinders to spread the load over vs 8? It's hard to imagine anything more durable than a V-10. Oh well, only 150k on my V-10, and I'm just pulling an Ollie. It'll be a while before I need a new one.- 1 reply
- 2
Thanks John. That pump is similar in capacity to the one I have. Since I keep my spares topped off and my tires inflated properly any non-junk compressor should work adequately well. The ones I'm considering would have an air reservoir to blow out window channels, etc. Since neither can operate an impact wrench, I'm beginning to think the differences between them are academic. BTW I bought a Viking jump pack the other day like you have. I'll probably keep it in my jeep since I have a 770 amp jump starter for my tow vehicle, a V10. Very impressed with the little Viking.
Hello Kids, I was wondering what kind of air compressor to buy. I have a tire inflator from HF that has performed well, a VIAIR knock off that I keep in my truck. Home Depot has a Ryobi 18V 1 gal, and Ridgid 18V 1 gal, that I am looking at. The Ridgid takes two batteries (will work on one) and since I already have Ridgid 18v tools for the Oliver I may go that way but it is 100 dollars more. And bigger by a significant amount. Neither will operate an impact wrench for removing lug nuts. What do you guys carry on the road? Which way would you go here? Mingy
