Badger
    590
    2020
851 profile views
Badger's Achievements
Apprentice (3/14)
1
  1. Thanks Steve, we have a Norcold. I just turned it off and then back on and it is running so I’ll check on it in an hour. All of our gas burners are working. I was just wondering if I have it on DC just to be safe. Should I be hearing something coming out of the Outside vent?
  2. in preparation for my departure tomorrow, I fired up the fridge using gas and it ran for several hours now went quiet and is showing an F. I switched it to DC. But I don’t hear it running or anything coming out of the exhaust by the outside door I checked my propane tanks. I have gas and the burners are working fine next step?
  3. I need to replace the plastic threaded piece coming out of the back of my toilet that connects to the water supply line. I also want to purchase the Oliver front hitch storage basket. I don’t see a tab for parts anywhere on the Oliver site. Do I need to call the factory or can someone lead me in the right direction thanks.
  4. Thank you Bill! 😁
  5. Hello, I am a new Ollie owner, Hull number 530, and I’m a low tech user who needs help! Where can I get information on purchasing the factory front mounted storage box I’ve seen and heard about? Secondly, what is my first step in troubleshooting low water pressure coming from my pump? Thank you. Pete
  6. Other than sitting it on the hitch shelf….. thanks
  7. Thank you Phil! Ordered....
  8. More dumb questions! I'm a novice. So I have the legacy II, 2020. I put 4 new interstates in it. Now that I am back in my barn and plugged in to shore power. everything is working! A/C, batteries got restored, outlets working gfi ,yes! So I think my portable Generator 30 amp plug was not working? battery drained after 2 days . here is my questions. Do the outlets in the RV work on battery power only? I thought so, and That may have been my first misdirection... Do I have an Invertor? What is the Black box mounted on the inside compartment under the table? Looks like an invertor.
  9. I DO! Hull # 590.
  10. My outlets aren’t working under battery power or shire power? The GFI has no indication light. I checked the fuses, breakers, even took the cover off the inverter and confirmed the red LED light inside is on?? What next?
