Mark Meadows
Everything posted by Mark Meadows
  1. These plastic caps that seem to come off once a year
  2. Ok thanks maybe I’ll just remove the others. I wasn’t sure if they had a purpose. Thanks
  3. Merry Christmas all. Does anyone know where to get replacement hub caps for my 2023 Oliver Elite ll ?
  4. Thanks for suggesting that. I will!
  5. Good idea! Thanks!
  6. You sound like a real craftsman! Not sure I would attempt vent changes but it might be the best thing. Thanks
  7. I’ll be setting my thermostat at about 68 in that kind of weather from now on. I’m learning the hard way as usual!
  8. Thanks , I have the 2023 E2. I think that turning up the thermostat and keeping the wet bath door opened will probably heat that area enough but we’ll see. I’ll be heading back again soon so I hope that will be enough. If not I’ll be back here crying about it! 😂
  9. Thanks , I have a spare 20 that I take along
  10. Ok thanks , I’ll do that ! thanks for responding Bill
  11. Oh ok! I’ll remember this since I’m going back to that same area again in Feb. thanks for responding!
  12. Congrats to you! That’s amazing!
  13. This is the first time I’ve put my E2 to the test so maybe someone can give me ideas. I found myself in El Morrow National Monument at 6 degrees with the pipes frozen in the wet bath. I had the antifreeze kit for the Truma Aquago plugged in and the inside heat at 58 degrees. What should I do different to keep the pipes from freezing? Maybe (4 season) isn’t what I thought it was. Thanks for any help !
  14. Yes I believe that’s what it is. One long hinge that runs top to bottom
  15. I’m in Southern California and I think the closest is in Oregon so it wouldn’t be very economical
  16. Hi all, Picked up my Oliver E2 in August of 2023. Recently I’m noticing the sagging of the wet bath door so it drags at the bottom enough that the door won’t shut without a little help. Spoke with Mike at Oliver support and he mentioned they have had some bushings going out on some of these. Does anyone have a DYI fix for this ? Taking it 2000 miles to their shop gets a little pricey. Mike suggested taking it to an RV repair shop locally but if I can fix it on my own I will. thanks for any information you all might be able to pass on! Mark
  17. Thank you very much! Good information to have!
  18. Thank you John! That does help. I have this f-150 that I can plug into at night to keep my batteries charged. Once I get back home I’ll start a routine similar to what you’ve outlined.
  19. Thank you very much! I’m glad to hear that and I’ll check with the manufacturer to be sure
  20. Hi all, What is the best way to make sure my AGM batteries last the longest. I saw something about turning the solar system off once the batteries reach 12.5 volts but Im not sure when (what voltage) I would start the Solar System to charge them up again. I keep my trailer at my home so its easy fro me to monitor . So far I’ve been allowing the batteries to charge with the solar panels non stop. Thanks for any suggestions
