Going Coastal
235
2017
Going Coastal's Achievements
Miles per gallon with a diesel?
Going Coastal replied to Dave and Kimberly's topic in Welcome to the Oliver Forums
If you are worried about MPG, get a gasser. Prior to 2005, when diesel cost less than gas, you would pay the 10k upfront on a diesel and recover it on fuel economy overtime. That has not been the case in 20 years. A diesel will cost you more due to fuel cost, filters, additional maintenance cost, etc. The only reason to get a diesel is if you need the towing capacity. That is not the case with an Oliver. I have a 2006 F250 with the 6.0 that I bought new...have about 250k on it... and get 14-15 mpg when towing in flat areas. My next truck is going to be the new GM gasser 3/4 ton with the allison tranny. I would not buy a new diesel for an Oliver. -
LE1 Generator Selection
Going Coastal replied to My Imagination's topic in Mechanical & Technical Tips
Steve, Your link is to the correct one I got, which runs off gas or propane. The one I linked to runs off just gas (I believe) ...I think it's a misprint on Amazon. -
We picked up this generator a few weeks ago. We have an LEII w/dometic...I wanted something that I could run ac, micro, hair dryer...and run on propane or gas. Amazon.com : Champion Power Equipment 4000-Watt RV Ready Portable Inverter Generator with Quiet Technology and CO Shield : Patio, Lawn & Garden -
Replacing shocks when upgrading leaf springs
Going Coastal replied to John and Debbie's topic in General Discussion
Thanks for letting me know...I have my trailer on jack stands w/ wheels off waiting to install these...no telling when they will actually show up....I wonder if these are even better than the monroe shocks. -
I'm in the same boat...I ordered from 4State 3 weeks ago...and received an email last week stating they would be drop shipped from their supplier the Week of September 1. Not sure when I'll get them. -
I posted previously about our Truma with busted tank and circulation valve due to me not draining and winterizing. I went with suburban due to: 1. Truma will not sell you spare parts. Truma requires you to take their products to one of their authorized dealers. I prefer to fix my own stuff. I'm an engineer as well (structural) and a bit of a control freak. 2. Cost. To have the tank replaced at closest authorized dealer (2.5 hrs away) was $1000. Didn't make much sense to me to spend that much and some other part could fail on a 7 year old water heater. I could buy like 5 suburban water heaters for the cost of one truma. 3. Redundancy: gas and electric vs. gas only 4. Simplicity: There is not much to a tank WH...I pulled out the Truma and took it apart to consider repairing (epoxying the tank and circ valve). Truma is far more complex. 5. Past Experience: Had 6 gallon tanks in past 3 trailers...never had an issue...and I have never drained them for freezing (live in the deep south). The only PRO (for me) that I can think of for the Truma would be the ability to stay in the shower as long as I wanted, but my wife and I can both take a shower on 6 gallons and not have an issue. Thanks!
- 17 replies
- 11
I recently replaced our Truma aquago with a Suburban DEL hot water heater in our 2017 OE2. It wasn't that difficult of a project, but took a little time. A few things required: Spliced into fridge 110 line under sink w weatherproof box. John Davies created a very detailed post on this. The DEL model has both gas and electric switch inside the trailer...Installed switch where Truma switch was...had to run some wires to switch, then to HWH. Move gas line over as suburban is on opposite side of Truma. Overall, not a bad project and wife is happy to have hot water again!!!
MAX Burner started following Going Coastal
What exterior caulk is the factory using now?
Going Coastal replied to Townesw's topic in Mechanical & Technical Tips
We had the same issue with our rear window caulk being a yellow color. I re-caulked all our exterior windows last fall, removing the caulk with a plastic razor blade and replacing with ASI 335. I don't know where I found this information, whether it was somewhere here on the forum, or in a discussion with Oliver directly, but there is a black butyl sealant they use on the windows that will react with the caulk and turn it a yellow color. I have actually done our back window twice, and each time, it stays white or just not as yellow as before. This is only on our back window, haven't seen it anywhere else! -
Truma Water Heater Leaking
Going Coastal replied to Going Coastal's topic in Mechanical & Technical Tips
So to leave the hot water tank on during a freeze, do you have water running to the trailer? Are you draining the Truma as well? Would turning the hot water tank on (truma) which has been drained, not damage the water heater? We are in Central Mississippi, which has some winter days with temps below freezing and then warmup up the next day. This year we have had one "hard freeze" where temps do not come above freezing the following day. BTW, this repair can only be done by a Truma authorized dealer (Truma will not sell parts for you to fix yourself). Just talked to a dealer and it is $1000 to replace the Truma tank. I asked the Truma dealer what was so special about the truma vs. the traditional 6 gallon heater. He said they rarely have repairs for things like the boards...which seem to hold up well. But they do freeze quite frequently and they keep these tanks in stock....And this place in in South Louisiana!!! MAKE SURE YOU GUYS ARE DRAINING THE HOT WATER HEATERS!!!! -
Good points GJ. I will check out the videos! -
Thanks Jason. We bought the trailer used and didn't realize I had to do anything to the water heater...lesson learned!!! We've had 2 stick built trailers in the past that had the 6 gallon water heaters and never flushed those. -
Yes...Truma is original. Trailer was outside,not in a heated storage...we hadn't used the trailer since Thanksgiving...so been exposed to several freeze cycles. -
VID_20240214_192445088.mp4 We just hooked up to the City Line in our OEII at a camp site and have water pouring out of the side of the round black tank in our Truma water heater. I did not do any winterization other than draining the fresh water tank and disconnecting water to the trailer. Could water have been in the round black tank, froze and busted it? I also did not have a pressure regulator on the end of my drinking hose...so I don't know if the camp site water pressure caused it. I did pull the yellow handle down and the 2 o rings are there and look good. Will post a photo. Thanks in advance!
