My Xantrex Freedom X Pro inverter displayvpanel is flashing (20)!. We are plugged into the campsite 120/30 amp post and all trailer systems are operating OK. Frig on AC and 120 outlets work.
Why the flashing code? No 20 error code on page 389 manual.
Thoughts?
I had this problem several times. After I reset the breaker located in the space under the bed near the inverter. I then change the setting in the Xantrex app "Breaker Rating" to 15A . I was plugged into a household 20A receptacle and I think that may have had something to do with it. Good Luck.
Check this link https://support.olivertraveltrailers.com/portal/en/kb/articles/xantrex-inverter-error-20
Hull #1238 - 2022 Legacy Elite II, TB, TV 2017 Tundra TRD.
States Visited Map
Thanks...will try.
I only had this problem at one campground.  It happened repeatedly throughout the weekend and never since. Later when reviewing the campground info it seemed to imply it only had 20 amp service on the 30 amp side. I didn’t think that was possible, but the error never happened again at any other campgrounds.  Interestingly I’m headed back there in a month and will see what happens.
Robert and Cheryl, Louisville, KY, Legacy Elite II 2023 Hull #1390 Oliphino, TV F250 Tremor
Arronorange....followed the instructions and all is well now. Thanks again.
