Got this specifically for boon-docking/backup. It will pull from 100 ft away and uphill 20 ft. The best thing is you can use it as a general systems water filter all the time without the pump turned on. Not the smallest or the lightest but well built and should help us with better tasting water and carrying less on trips. Runs off 12V from SAE solar port. This was me just trying it out, not the home for it on the TT.
IMG_7577.thumb.jpeg.a01da6cdb66af676075ea3cb46f2b827.jpegIMG_7576.thumb.jpeg.0b8d74268c2ae0e67a4a97cda3a2e01b.jpegIMG_7579.thumb.jpeg.88612fc8f43d409fc9b19f4a948d5ec4.jpegIMG_7578.thumb.jpeg.2b509a44c35485e090ed4df2b3cbcb95.jpeg
Edited by rideadeuce
  • Wow 2
  • The title was changed to Nomad water filter and pump for boon-docking
Interesting (and expensive), what are you using for the 12VDC connection?
edit:  oops, disregard.  I see it going to the SAE connector.
Edited by Wandering Sagebrush
Hull #364 - The Roadrunner
2023 F350 CCLB SRW 6.7L
Nice.  Was wondering if there was something out there like it.  I do not have a 12 volt connection on mine.  Guess I could tap into the front jack power.  Do you still like it?
Phil Drye
Hull #246, 2017 Elite II
