Just so happens, SDG is only 45 min from my dad's house in MI. So I have made an appt for the Atmos 4.4 to be installed July 17th. I am hoping to get some good pictures of installation since it will be the first install for them in an Oliver.
Things I already know:
No condensation pump or lines
No need to use wall mounted thermostat due to Plenum, remote and app controls.
If you keep the suburban propane heater, they will mount a simple thermostat for it under the street side twin or elsewhere that is convenient. May or may not use the propane heater any more since the Atmos has a 12k heat pump.
They can re-use my SoftStartRV from the PII.
The Atmos is almost the same footprint. 2.5 in longer and an 1 in taller.
Much quieter and more efficient.
I will update as things progress.
Best,
Mike
