I have been in contact with OTT Service department recently, to ensure that I have my Xantrex settings correct, before I test out using a small generator that was given to me. I plan to post a separate thread about the generator, but during this conversation with OTT Service, we were unable to find the definition of a setting labeled "nAt". Anyone know what it stands for?
For reference, here is my description of it and the OTT Service response. Apparently it's not a setting that can be set via the Xantrex bluetooth app, but has to be done by using the Xantrex Panel. That is a process that I have not succeeded doing yet, as I get lost in the endless codes and can't seem to follow them from one screen to the next, book in hand.
MY QUESTION TO OTT SERVICE:
Checking through my Xantrex Settings, I noticed the following settings on MY XANTREX APP are different from the "normal recommended" settings in the Knowledge Base article. (The Xantrex App doesn't provide the setting #, only the setting name; I've tried to insert the setting #s here for clarification).
INVERTER (heading on app)
#13 Inverter Shutdown Recovery -- mine is set at Manual Restart. In MY MANUAL for 2022 Elite 2 components, the default setting reads "Manual -- Man".  On the app, my Xantrex is set to "Manual".  BUT on the OTT Knowledge base it says the setting should be "nAt" and I don't find that defined anywhere ... I am still not sure what this setting should be.
OTT SERVICE RESPONSE:
I cannot find a definition of that abbreviation but this is the setting that would need to be changed through the panel.
I want to note that OTT Service department has been extremely helpful to me.
my Oliver has camped here
nAt is manual restart. This default value is the recommended setting for #13. The following may be helpful either to you and/or others.
IMG_6335.thumb.png.179af22137e4188b59e0025181a89fd8.pngIMG_6336.thumb.png.13a664323160764a279eece9c9ea63ad.pngIMG_6337.thumb.png.5a3bb42a3085f1f3eac886f613a06870.png
Sent to me by Oliver at my request.
Edited by Ronbrink
2020 OLEll, Twin, 579:
This explains the process in using the remote wall panel to change the Xantrex settings.
I've done that a few times, and get lost in looking for the setting number. j
Do you see that the nAt means "Manual Restart" -- and on the Xantrex App it uses the abbreviation "Man" for Manual Restart. So my conclusion is that I CAN use the Xantrex bluetooth app and that mine is set correctly. I think this confusion is due to Xantrex not correlating their abbreviations from the panel to the app.
THANK YOU for finding this. I will share with Mike at OTT Service.
My Xantrex 2000 is not BT capable, but find using the remote panel easy to pan through the settings and make changes. I obtained the settings table from Oliver when converting to LFPs; only difference in my specific settings were #9 set to 2.0 (inverter is 2000W [2.0] rather than 3000W [3.0]) and #24 set to 80 (2000W inverter/80A charger rather than 3000W/150A charger).
Edited by Ronbrink
