Marce Posted July 19 Share Posted July 19 Anderson chains: can anyone tell me what grade/length I need for replacement chains? Mine are rusty and If like to replace w/ yellow chromate anti-rust linkage. Thanks in advance! Link to comment Share on other sites More sharing options...
jd1923 Posted July 19 Share Posted July 19 (edited) I would replace them with same spec as what was OEM installed. Measure your overall length, count the links, measure the length and diameter of each link. The only clue that perhaps you have an older hull is "rust" since you have no signature. Live in the rustbelt? Ours was in the MW when first bought, down in AZ for years now and the chains look like brand new shiny chrome. They installed 3/8" hardened chromed links on ours, each link 2" long. Get highest grade available in the correct size. Overall length +/- a link could depend on where the Anderson mounts were bolted into placed. Edited July 19 by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
srthomsen Posted July 20 Share Posted July 20 https://olivertraveltrailers.com/forums/topic/10231-andersen-hitch-install-photos-advice-le-ii/?do=findComment&comment=108108&_rid=8475 Link to comment Share on other sites More sharing options...
