Boilermaker Chemist Posted September 13, 2024 Posted September 13, 2024 I am posting this in case anyone else has the same problem. The gooseneck on one of my reading lights came loose. The flange is attached to the ceiling with two rivets. I drilled out the rivets with a 1/8” drill bit to get access to the lock nut that holds on the gooseneck. I removed the lock nut, coated the treads with Blue LocTite and re-tightened. Then simply reattached the flange using 1/8” diam x 3/8” long rivets. Problem solved. 1 5 Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
Patriot Posted September 13, 2024 Posted September 13, 2024 @Boilermaker Chemist Nice job! It’s just another one of the fasteners that may at times loosen up with the earth quake happening whileunder way. I try and make it a point to check all the fasteners especially during a long trip. This morning I just completed a “snug tight”check on the pex connector white compression fittings below deck. I always manage to find one or two that just need a good hand tightening. 5 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Boilermaker Chemist Posted September 14, 2024 Author Posted September 14, 2024 On 9/13/2024 at 11:45 AM, Patriot said: @Boilermaker Chemist Nice job! It’s just another one of the fasteners that may at times loosen up with the earth quake happening whileunder way. I try and make it a point to check all the fasteners especially during a long trip. This morning I just completed a “snug tight”check on the pex connector white compression fittings below deck. I always manage to find one or two that just need a good hand tightening. Thanks for the tip on checking the compression fittings. I will do that. 2 Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
