Clip18 Posted September 22, 2024 Posted September 22, 2024 Hi. I’m following the Oliver Winterization video step by step. All pretty straightforward. I’m at the step of pumping antifreeze into the fresh water tank. I’ve drained it as fully as I can, but it isn’t clear whether or not I should close the drain valve before putting in the antifreeze. Maybe a silly question; I just wasn’t sure.
dewdev Posted September 23, 2024 Posted September 23, 2024 (edited) Yes, I close the drain valve. From my experience, I want the antifreeze in there as you can never get all the water out of the tank. In the spring, it is all flushed out and the tank disinfected. Edited September 26, 2024 by dewdev 1 Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine
GraniteStaters Posted September 30, 2024 Posted September 30, 2024 The step for winterizing the fresh water inlet is really to prevent damage at the check valve where some water may accumulate and not drain due to the design of the check valve. I have never added any significant winter antifreeze in the freshwater tank because if it drained, there is very, very little chance that any freezing would damage the tank. Imagine an ice cube tray with a bit of water in the bottom of the tray. Any freezing water would just fill the void and not press any significant issue to the sides of the water tank. 2 David Caswell and Paula Saltmarsh Hull 509 "The Swallow"
