A comment by KatanaPilot mentioning his profile picture made me away of that feature that I had not previously noticed. I thought “cool! I can add a profile picture.”
I did.
Unfortunately, because of the member name and other stuff the system places over the top of the photo, you can’t see what’s in the center of the photo - like where most photographers put the subject of the photo.
I tried clicking various things to see if the system would let you uncover the photo or have it pop up in a separate frame, but so luck.
I guess I can go in and resize and crop the picture to move the subject off to the side. That would make MY profile picture more effective, but I wanna be able to see the planes on KatanaPilot’s profile picture! (I like planes.)
(Hopefully the examples below illustrate my point.)
King Bed Floorplan
electronics package
Truma Aqua-Go
LOUD Dometic Penguin A/C
LevelMate Pro+
RealTruck hard tonneau cover
Rove R2-4K DashCams
I don't think that I'm absolutely sure of exactly what you are trying to do.  However, if you are talking about the photo that is at the top of the page where your profile can be seen and/or changed (by you); you can easily "reposition" this photo (vertically only) by clicking on "cover photo" (located at the top right of the page).  Then click on "reposition photo".  This allows you to move the photo up and down until you get it positioned exactly where you want it.
On the other hand - if you are trying to replace the "G" that shows along with your posts on the Forum then; Go to you profile page (simply click on the offending "G") and then click on that little blue "mountain picture" located at the bottom left of the "G" at the top of your profile page.  Another menu page will pop up where you can upload a picture of your choice that will not have that blue "G" in it.
Hope this helps!
Hope this helps!
That sounds like it would help somewhat, but see how both my and KatanaPilot’s name is plastered across the center of the profile picture? That’s what I’d like to remove or reposition to be able to see the picture. Otherwise, a landscape or skyline picture would be the only kind of picture suitable for that use.
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
OK - I'm guessing that you are using a cell phone and that is what you did the screen shot that I see above.
I did move your profile picture slightly higher for you but if you don't like it there you can simply move it back or let me know and I'll move it for you.  Given the height difference between the two of you I do not see a way to get both of your faces in that picture without cropping the picture and moving your faces to the right.
Assuming that I'm correct about the cell phone usage - please let me know - I'll have to investigate what can be done (if anything) to get more of your picture visible.
Thanks Bill,
     I’ll probably edit a picture - maybe splice two together - to make up a profile pic that puts the items I want to accentuate on either side of the stuff that covers up the middle of it.
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
I think I found an answer:
select a picture that works in this application.
Done!
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
Nicely done!
Now - work on that big blue "G".😁
Edited by topgun2
spelling
