One of the first things that I did after I bought my Winnie Minnie back in 2020 was to install a rear view camera. After doing some research, I chose the Haloview MC7108 Wireless RV Camera with 7'' Monitor. I was not disappointed. It had excellent resolution and the image on the screen had brilliant color.
Fast forward a few years and I bought the Oliver. Although nearly everything about the Oliver was an upgrade, IMHO the Furrion rear view camera was certainly not. First, the image on the tiny 4” monitor was so small that I could hardly make out any detail. Even worse, the image brightness was so poor, if I had my sunglasses on I couldn’t see anything but a blank screen (yes, I tried adjusting the brightness and contrast). So I finally scrapped the infuriating Furrion and replaced it with another Haloview MC7108. I am very happy with the replacement.  Below are the details of my installation.
In making modifications to the Oliver, my number one rule is to try to avoid drilling any additional holes in the fiberglass. With that in mind, I also purchased the Yinettech Camera Bracket Adapter Kit for Furrion. The steel adapter plate is made to screw onto the Furrion “shark fin”. The kit also included a Pig Tail Plug Adapter since the plug on the Furrion camera is not the same type as the one on the Haloview.
It turns out that the Haloview camera is much heavier than the Furrion. So I was concerned that the plastic “shark fin” might not hold up over time, especially considering my lengthy travels and the state of some of our roads. Also, the Haloview camera comes with a rather long cable which won’t fit inside the “shark fin”.
Rather than take a chance on using the “shark fin”, cut the cable and make new connections, I chose to mount the camera on top of a Carlon PVC Type 2FSE electrical box. This provided plenty of room for the long Haloview cable and the Yinettech plug adapter. So the wiring was essentially just plug and play.
When I removed the “shark fin” gasket from the Ollie I noticed that the area underneath it had been filled with caulk and this was raised above the fiberglass. I decided not to disturb the caulk around the opening for the cable since it was in good condition. Instead, I cut an opening into the bottom of the PVC box to accommodate the raised area and thereby allow the box to sit flat on the fiberglass.
I cut off the mounting feet on the box and using the Furrion gasket as a template, drilled holes to match the existing ones in the fiberglass. Since the PVC box was grey, I sanded down the exterior, wiped it down with acetone and then applied several coats of Krylon Fusion All-In-One Gloss White spray paint and primer. This paint is formulated to bond well to plastics like PVC. A weatherproof cover plate was treated similarly and painted.  Coincidentally, the rubber gasket that comes with the camera also fits nicely inside the conduit opening. Adding a PVC conduit adapter holds the gasket firmly in place.
IMG_9802.thumb.jpeg.d235fc45221081273fed0c2763f7bbaa.jpegIMG_9793.thumb.jpeg.e58d665d835d7ed93b6d5c6e98045e11.jpeg
In order to keep water out, I overlapped butyl tape all around the bottom edges of the PVC box, covering the screw holes. I then secured the box to the fiberglass using the original screws that were used with the “shark fin”.
IMG_9805.thumb.jpeg.93dfb7835a2ddc61c5a483d8c1943ec6.jpegIMG_9807.thumb.jpeg.d24efc30bdc05ed7095f7b3eaa3019bd.jpeg
Next, I used Geocel ProFlex RV white sealant around the exterior edges of the box, the top cover plate and the bracket supporting the camera. Screw heads on the cover plate were sealed with the GeoCel and screw heads on the camera bracket were sealed with black Dicor.
IMG_9808.thumb.jpeg.610502957e649716cf98c55ec0176d79.jpegIMG_9823.thumb.jpeg.f4b3482cf5953ddb043d3bc93ceb709d.jpeg
Finally, I used two cable ties to form a drip loop on the cable to keep water out and used a gasket cutter to cut a hole in a rubber stopper to make an additional seal for the cable.
The Haloview kit comes with two nice options for mounting the monitor on the dash. One is a U-shaped bracket that can be secured to the dash with screws.
I chose the other which is the center mount bracket. It is simply attached to the dash with 3M tape but is very secure.
I am extremely happy with the addition of my new rear view camera system. I think the resolution and color of the Haloview system are exceptional. There are also a lot of extra features on the Haloview system that you will not find on the Furrion.
Edited by Boilermaker Chemist
Corrected margin issues
Mike
  • 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler
  • 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
Thanks Mike! After seeing your setup at Lake Guntersville, I ordered and installed the same unit, although I used the adaptor kit you had recommended and simply tucked the wires away under the camera.
Unfortunately, my experience was not as good as yours. I had frequent loss of signal, and terrible signal delay. To the point that a car would sometimes be beside me before it showed up as behind me on the display. But this only happened at highway speeds. It worked great when stationary or backing into a campsite. I thought it might be engine interference, so I put the truck in low gear at low speeds to get the RPMs up, but it still worked great then, too. Haloview Customer Service was useless in resolvingtheproblem. Looking at reviews online, this is a common complaint.
So I'm now back to the original Furrion camera. It's not great, but it at least works for me. If anyone wants a Haloview MC7108 for a truck camper or backup camera for a car that didn't come with one, I'll sell you mine for $100 plus shipping. Cost new in June was $200.
Steve - Northern Ohio, USA
Facebook - Instagram
@Steve Morris sorry to hear about your issues.  Knock on wood I haven't had any issues to date.  On my Winnie Minnie I purchased the external antenna and attached it on top of the air conditioner shroud.  You might try that.  But mine works fine on the Ollie without it.
Mike
Just to add one more data point, I made a frame with some aluminum angles, and mounted the camera itself on a vertical plate. I used a pair of rubber “bands” that mount the display on the rear view mirror. That makes it natural for a rear view. I have had no signal problems with the setup. I could not use the Furrion. I was actually surprised that it was so poor. My next step is to put another camera on the rear of my cap so that I always have a hi quality rear view.
Doug & Jill - Wilson WY
Ozzie and Ruby - 2 Havanese characters
“Hull #1491” ‘24 LEII
’23 F-250 RapidRed KR 7.3 Godzilla
  • The title was changed to Haloview MC7108 Rear View Camera Install
