RustyMD Posted November 17, 2025 Posted November 17, 2025 Where is the fuse for the Truma Vario Control panel? My Truma Vario Control Panel will not turn on. It might be the fuse. I have Hull #1304 a 2023 Legacy Elite II. Robert Youens 2023 LEII Hull #1304 TV 2022 RAM 1500 5.7L Hemi e-torque with tow package
Rolind Posted November 18, 2025 Posted November 18, 2025 I don’t know where the fuse is but I would start by removing the control panel and check the connections in the back. There may be a breaker in the panel under the small dinette on the front of the seat. Everything else on DC is working? Lights, fan? Switch on the hot water turned on? The only time I have seen my Truma display go dark is when I turn off the house batteries. Battery voltage ok? Robert and Cheryl, Louisville, KY, Legacy Elite II Hull #1390 Oliphino, TV F250 Tremor
RustyMD Posted November 18, 2025 Author Posted November 18, 2025 You can access the back from a porthole in the pantry. I didn’t see any fuses back there and nothing was disconnected. I looked at the 12 volt fuses under the dinette and all seemed fine. I pulled one that said heater I believe and it was OK. I’ll probably change any that reference any HVAC stuff but was hoping to find a secret fuse that was the one that powered the controller. Maybe it gets its power from the individual components. Thanks. Robert Youens 2023 LEII Hull #1304 TV 2022 RAM 1500 5.7L Hemi e-torque with tow package
Ronbrink Posted November 18, 2025 Posted November 18, 2025 10 hours ago, RustyMD said: I looked at the 12 volt fuses under the dinette and all seemed fine. You might want to check the actual wire connection, I had one of the spade connectors come loose and resolved a similar electrical problem by simply squeezing the connector with pliers for a tighter fit. 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
RustyMD Posted December 11, 2025 Author Posted December 11, 2025 The Truma display/control panel is fixed. I took it to Auer’s RV Service Center in Georgetown, TX. They are a certified Truma Partner. The technician pulled the display panel. He did not find anything wrong but disconnected all the wires, checked the voltages and reconnected them. The panel lit up. He thought it might have been a loose connection in a Wago connector. Thanks for your guys thoughts. I was afraid I might mess it up worse. 1 Robert Youens 2023 LEII Hull #1304 TV 2022 RAM 1500 5.7L Hemi e-torque with tow package
