Doing a search I only found this thread which sputtered out ..
One of the few things I’m disappointed in with the Oliver is the outdoor shower (the other being the Bluetooth speaker). It’s annoying to use and is limited as just a basic shower head. On our last big trip, out in Arizona at a carwash giving the car and Ollie a bath I had an Airstream couple ahead of me with a neat and useful mod. They had replaced the outside shower with an plug in style unit they used to wash the trailer. So you could plug in (via water hose quick connects or the like) a garden hose, a shower head or whatever.
Also our storage lot doesn’t have water. I can bring 10g of pressurized on my truck, but a full 30+ gallon tank onboard would be useful. If I could just get to the water …
  • I’d like to modify the Oliver as little as possible. Ideally not drilling holes
  • Wouldn’t mind getting rid of the old shower and putting a new one in the same spot, probably the best solution.
  • Has to have quick disconnects and can add new attachments, so the fittings should be standard
  • Would like some kind of high end or marine solution ideally
One option is this Empire RV faucet from eTrailer
Cons, would need a case to be set back far enough. Also kind of typical plastic solution. But works otherwise
Another solution I like better is this - could have separate hot/cold or just cold. I don’t see needing a hot line.
Cons, it’s just ABS plastic. No temp connection, but which might be OK
Now for marine application are washdown connections
Here’s one, nice stainless with easy twist. No temp control but I can attach my favorite garden hose quick connects
Again needs a deeply recessed box to contain this.
Any other ideas?
Sierra EV AT4 2026 (max range 530 mile pack)
