I have had a problem with my chains falling down in the campsite at night and getting dirty or even worse, my TV electrical plug falling and getting sand in the connections !
I have found this "gadget" from GR Innovations LLC,  that solves this problem.  This is a metal plate that attaches to the front Jack  and has 3 holes and a slot.  The slot is to place your TV plug and the holes are to put your chains in.  (One extra hole!)
The black Towing Organizer (I think it may be hard plastic) sells for $19.95 and the aluminum unit sells for $29.95.  Both come with the blue 7 way plug cover or it can be puchased separately.  It includes everything you need for installation which takes 2 minutes to install the two bolts and tighten.   I did not buy the plug saver tether, I prefer to make my own.  The chain saver organizer is well built and easily installed
coy
The address is grinnovationsllc.net
  • Thanks 7
