Mystery switch
Bshaffer
 Share
It turns the water pump on or off, like the switch in the galley.   Note - if you flip the outside water pump switch and do not return it to the original position, your inside galley water pump switch operation will be reversed.  To use either of these switches, the water pump must be enabled on the master panel, just inside the door.
 Share
