Can/should we, as owners, change the fuses in the Blue Sea Systems Circuit Breaker Panel? If so, how? :)
I have been to the Blue Sea web site & cannot locate; I have looked at equipment in trailer & cannot figure it out. And, I have looked in the Forum. All to no avail.
Please know that I am not 'electrically' educated nor do I have an interest in the subject. I am the information gatherer in our duo. I collect the information, documentation & supplies, as needed, & provide to fairly well electrically educated other half.
Thank you.
SGC & GRC
Hull 224 [2017]
2017 GMC Sierra HD Crew Cab Diesel
ALARDEFLGAINLAMEMDMNMSMOMTNJNCNDOHPASCSD   Map of Provinces I Visitedimage.png.f8ebba1142570e619cdfe801998f4b4d.png
The breaker panel doesn't have fuses that need to be replaced.  If a switch should pop, just flip it back to its normal position.  Should it do so repeatedly, then you should leave it off until you've identified and corrected whatever is causing it to blow.
