We are living full time in our Oliver while having a home built (in pretty warm temps) and have noticed the A/C dripping some on the inside. I assume/suspect the condensate drain is clogged but am not sure how/where to access it (from the top) after removing the cover. Any tips or advice on this maintenance appreciated.
Darrell & Kathy
2013 F-250 Diesel 6.7
2018 Oliver Legacy Elite II (Hull #319)
https://www.blogger.com/profile/02054187086533485920
 d
Is the AC drain at the rear street side dripping water?
If you remove the return air filter inside the cabin, will be able to see the drain hoses.
