44 minutes ago, jordanv said:
Does anyone in this thread have the 'Micro Air Easy Start' option added with the 4 AGM batteries + Solar Panel?
Is the micro air easy start something we should get if we do the solar option?
If you're going to use the Yamaha 2200 or the Honda 2200, I'd opt for the East Start. Oliver only charges $100 over retail for the installation. If you're using AGM, the AC won't pull from your batteries. You'd be running off shore or generator power. The Easy Start allows the AC to start when using generator power.
Generator power, settings (eco mode), propane mods, elevation changes, and ambient temp can all impact the successful startup of the AC when using a generator.
Edited by Jairon
2019 Toyota Land Cruiser
Thanks for the help with this ya'll 😃
I think I'll go ahead and add this in, as we do have a generator, and may want to use that to power the AC when in warmer climates + boondocking.
