Chris Scarff Posted June 18, 2021 Posted June 18, 2021 I have two grills. I'm trying to get one of them to work with the rear outside propane connector in the Elite II. Have a brand new Blackstone and an old Coleman stove and I have the extender gas hose/line; it's about 10 ft long. I cannot seem to get gas to go through the line. The furnace and hot water heater both produce heat off the gas. I don't see any shut-off valves anywhere. What could I be doing wrong? I see nothing in the Oliver guide in regards to the external gas connectors, front or back. Thanks. Chris 2016 Legacy Elite II o-o Hull #110 o-o "Rock'in 110" o-o Wayfinder (old) o-o Twin Bed 2020 RAM 1500 Limited 5.7L Augusta, Georgia
Time2Go! Posted June 18, 2021 Posted June 18, 2021 From what I remember, once the quick connect is attached and in place, there is a small on/off lever that is black on side of the quick connect, you will need to turn it parallel to the supply line. Hope this helps. Cindy Charlie & Cindy / Cleburne, TX / 2021 Elite II Hull #743 / 2013 Ford F250 Diesel 4WD Supercab States we've camped in our Oliver:
Chris Scarff Posted June 18, 2021 Author Posted June 18, 2021 That might have been it or I did not have Blackstone connector tight enough to push in internal hose pin, or I'm a moron and did not wait long enough. "We're cooking with Grape seed oil now". I suppose Crisco sounds better but, yuck. 1 Chris 2016 Legacy Elite II o-o Hull #110 o-o "Rock'in 110" o-o Wayfinder (old) o-o Twin Bed 2020 RAM 1500 Limited 5.7L Augusta, Georgia
Time2Go! Posted June 18, 2021 Posted June 18, 2021 1 hour ago, Wayfinder said: That might have been it or I did not have Blackstone connector tight enough to push in internal hose pin, or I'm a moron and did not wait long enough. "We're cooking with Grape seed oil now". I suppose Crisco sounds better but, yuck. Glad you got it figured out! I've got another 25 minutes of work and we'll be headed out for the weekend at a state park about 2 hours away. We'll also be connecting the Blackstone and be enjoying some good food! Cindy 1 1 Charlie & Cindy / Cleburne, TX / 2021 Elite II Hull #743 / 2013 Ford F250 Diesel 4WD Supercab States we've camped in our Oliver:
