This is such a silly, simple thing but once I discovered this trick I use it quite often so I thought I would share it.  When sitting at the forward dinette by the bathroom, I do not always sit straight ahead facing across the table or straight out facing the door.  I'm usually sitting at a 45 degree angle facing into the kitchen.  The trick I discovered was to take the backrest dinette cushion and put it diagonally across the seat at a 45 degree angle.  When I rest against the back cushion. it wraps around my back and makes a very comfortable backrest.  I've attached a picture so you can visualize its position.
Have you discovered other simple tricks in your Ollie that make a difference in your comfort?
  • Like 7
Last night I tried using the back cushion from the dinette as a back support for sitting upright in bed. Worked brilliantly, and as with most things Ollie related, I saw this trick on the forums!
MaryBeth
Boulder, CO
2022 Elite II #953
