Jheim Posted September 23, 2022 Share Posted September 23, 2022 Hi so I want to take pressure off of the levelers and use jack stands. Question is where is the jack point exactly? Is it at the sticker that says, "jack point"? Or can I put it on the beam? I just don't want to break the weld on the beam but it looks like it would hold much safer. Link to comment Share on other sites More sharing options...
Frank C Posted September 23, 2022 Share Posted September 23, 2022 !!!! DO NOT USE THE JACK OR JACK STAND ANYWHERE ON THE FIBERGLASS !!! The jack points are on the galvanized steel subframe at the locations indicated by the stickers. Those are the main frame rails that support the trailer. ALWAYS jack on the steel subframe. 1 2 Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted September 23, 2022 Moderator+ Share Posted September 23, 2022 4 hours ago, Jheim said: Or can I put it on the beam? I just don't want to break the weld on the beam but it looks like it would hold much safer. You are correct that it would hold better and be much safer directly under the welded beam. Say the jack stands were placed adjacent to the beam with the weight of the trailer resting on them. If the trailer shifted and slipped off, the stand would either take out the fiberglass on the outside wall or punch up through the floor. Also remember to always do work under the trailer while it is securely hitched to your truck. 3 Steve, Tali and our dog Rocky plus our beloved Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
Jheim Posted September 24, 2022 Author Share Posted September 24, 2022 5 hours ago, Frank C said: !!!! DO NOT USE THE JACK OR JACK STAND ANYWHERE ON THE FIBERGLASS !!! The jack points are on the galvanized steel subframe at the locations indicated by the stickers. Those are the main frame rails that support the trailer. ALWAYS jack on the steel subframe. Thank you I agree! I would not put it on the fiberglass. I ended up putting it on the metal. Link to comment Share on other sites More sharing options...
Jheim Posted September 24, 2022 Author Share Posted September 24, 2022 5 hours ago, ScubaRx said: You are correct that it would hold better and be much safer directly under the welded beam. Say the jack stands were placed adjacent to the beam with the weight of the trailer resting on them. If the trailer shifted and slipped off, the stand would either take out the fiberglass on the outside wall or punch up through the floor. Also remember to always do work under the trailer while it is securely hitched to your truck. So I left the leveler down with a small amount of pressure on it. This way if the jack ever shifted the leveler will be right there to catch it before it goes through my fiberglass! Link to comment Share on other sites More sharing options...
