RustyMD Posted December 24, 2022 Posted December 24, 2022 How do you change out an empty propane tank while the heater is running? I assume you turn the regulator to the one now in use, change the primary tank (the one that’s empty) and then switch the regulator back to the primary tank. Yes? Or do you have to shut everything down? 2023 LEII Hull #1304 Robert Youens 2023 LEII Hull #1304 TV 2022 RAM 1500 5.7L Hemi e-torque with tow package
RustyMD Posted December 24, 2022 Author Posted December 24, 2022 Heater = furnace for this question. Robert Youens 2023 LEII Hull #1304 TV 2022 RAM 1500 5.7L Hemi e-torque with tow package
SteveCr Posted December 24, 2022 Posted December 24, 2022 11 minutes ago, RustyMD said: How do you change out an empty propane tank while the heater is running? I assume you turn the regulator to the one now in use, change the primary tank (the one that’s empty) and then switch the regulator back to the primary tank. Yes? Or do you have to shut everything down? 2023 LEII Hull #1304 Correct....no shut down necessary. After refill/install of tank 1, you can just leave the regulator on tank 2 if you want. 1
bhncb Posted December 24, 2022 Posted December 24, 2022 19 minutes ago, RustyMD said: How do you change out an empty propane tank while the heater is running? I assume you turn the regulator to the one now in use, change the primary tank (the one that’s empty) and then switch the regulator back to the primary tank. Yes? Or do you have to shut everything down? 2023 LEII Hull #1304 Yep. There is no need to switch regulator back to the just refilled tank. Whichever tank the regulator lever points to is/becomes the primary tank. 1
RustyMD Posted December 24, 2022 Author Posted December 24, 2022 Thanks for the quick replies. Only two more days of significantly unhappy weather here in south central Texas. 1 Robert Youens 2023 LEII Hull #1304 TV 2022 RAM 1500 5.7L Hemi e-torque with tow package
RustyMD Posted December 24, 2022 Author Posted December 24, 2022 Switch made. No explosion. Thanks again. 🤠 3 Robert Youens 2023 LEII Hull #1304 TV 2022 RAM 1500 5.7L Hemi e-torque with tow package
