Gliddenwoods Posted October 23, 2023 Posted October 23, 2023 Replacing co/propane monitor with new one due to several error messages. In the process I am guessing I blew a fuse. So where is the fuse? In previous discussions regarding these monitor someone spoke of an inline fuse behind the monitor below the seat; not on my 2022. So where and which fuse? Thanks for any help. 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
rich.dev Posted October 23, 2023 Posted October 23, 2023 It’s in that area where your inverter is under the steet side bed (front). 1 3 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Gliddenwoods Posted October 23, 2023 Author Posted October 23, 2023 Thanks rich.dev. 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Gliddenwoods Posted October 23, 2023 Author Posted October 23, 2023 Also received this from Mike at Oliver Service; more quality speedy customer service. ELITE 2 MODELS INLINE FUSES ARE LOCATED UNDER THE DRIVER SIDE BED ACCESS PANEL 1 4 1 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
