wolfdds last won the day on October 8 2019
wolfdds had the most liked content!
435
2019
wolfdds's Achievements
All set. But you have to question the logic behind putting a hole in a solid fiberglass camper just to caulk a plexiglass sign into it!!
After returning home I was able to better investigate the water issue. Turns out the attic was not dry. It was wet underneath the white insulation layer. I was able to easily peal the the insulation up. The leak was coming from the Oliver Sign. The caulk had dried and cracked. It is actually amazing how much water could get in from that source. All things considered this was the best scenario for the source of the leak. I was able to remove all the old caulk and re-caulk the sign.
I took the sides off in the attic. It is completely dry, even dusty. The only place that is even damp is right around the hole. I also took the inside cover off the AC. The inner seal is completely dry. I'm on the road and it's still raining, so I'll have to investigate on the roof more at home.
wolfdds started following Starlink Gen 3 DC power conversion and Water leaking from TV wire port in ceiling
After a heavy rain we have water leaking out of the port the TV wires come through? Has anyone had this problem? The attic is dry?? It seems to be coming from between the fiberglass layers. My initial guess was either the AC or the Oliver Sign. There is no leak around the AC unit directly in. The seal is completely dry and the Ollie sign seems fine. I have not had a chance to go onto the roof to investigate.
I just received my new Starlink Gen 3. I mostly boondocks and thought it would be a waste of power to convert DC to AC to DC to power the Starlink. I found a device that will convert DC 9-36V 15A to DC 46V 3A through POE. It also has a built in switch to deliver the internet signal to the router of your choice. (XLTTYWL Starlink V3 Poe Injector, 150W 2 in 1 GigE Passive & ESD Protection Starlink 12v Conversion Kit with Starlink DC Step UP Converter DC 9-36V/150W for Starlink Gen 3 Dishy) I am using a mini travel router (GL.iNet GL-AXT1800 (Slate AX) Pocket-Sized Wi-Fi 6 Gigabit Travel Router, Extender/Repeater for Hotel&Public Network Storage, VPN Client&Server, OpenWrt, Adguard Home, USB 3.0, TF Card Slot) uses a USB C power source DC 5V 3A. I wired a PlusRoc Waterproof 12V/24V to 5V Converter DC-DC Step Down Module Power Adapter Compatible with Raspberry Pi 4, Cellphone, Car (USB Type-C Connector) to power the router. I mounted everything on a board and powered it from the DC fuse box under the dinette. I will add a waterproof Ethernet port as shown in many other Starlink threads. It powered up and so far is working great. Even the Starlink mobile app recognizes the signal from the mini router and allows all the Starlink utilities to be used. I had a Victron Solar Panel Charge controller for a suitcase panel in the spot where I mounted the board so I just moved that to the board as well. I love not having to turn on my inverter to run the Starlink dishy.
- 3
I was able to find the part with Mike Sharpe's help. I am attaching the Barker parts list he sent me as a reference. He marked part #20 but that is the light switch. Part #9 is the up/down switch. Here is a link to the place I bought it from: https://pdxrvwholesale.com/products/barker-jack-up-down-switch-736-2300
Here is the update: I did the vinegar treatment to my water system today with great success!. The bathroom faucet is working perfectly now. I was amazed how fast the treatment solved the problem, the vinegar was only running through the faucet for about 15 seconds when the pressure started improving. However the toilet valve remained stuck open. I changed it out and all is good. The toilet valve was filled with debris...but it was easy and cheap to replace.
So it seems like the pressure to the toilet resolved but at the same time the valve stuck open. So I do think some debris has gotten in the water system which has effected the water faucet and the toilet valve. The toilet valve is easy to replace so I am going to do that...the faucet is not easy to replace so I am going to try the vinegar solution in the water lines to see if it will clear the faucet blockage.
My tongue jack toggle switch stopped working in the up position this weekend. So I was not able to raise my camper. Luckily the bottom half of the switch stilled worked, so I could lower it. As an FYI: If you switch the red and black wires around it reverses the action of the switch so the down position becomes the upward movement. I was able to rewire it back and forth to get my camper hooked up using the motor. Having the inline fuse right there to cut the power off/on while switching back and forth was convenient. (obviously it could be done manually with the crank as well but then I would not have had anything to post). 🙂
I am having the exact same issue...no pressure to the toilet or bathroom sink/shower. Was there a resolution to this issue? I did not see it in the thread?? I do not think my problem is a buildup of calcium or the screens as I have checked both??
My how-to video for cleaning the weep holes and tracks
wolfdds replied to Chris Scarff's topic in Mechanical & Technical Tips
Does anyone know where to buy replacement rubber strips and the felt sides for these windows? It was pouring out and our windows were leaking, in desperation I pulled the gaskets and felt but pretty much ruined it getting it out. The good news is that I was able to stop the leak after pulling out the gasket and cleaning the weep holes. Any info on buying new parts to replace the ones I ruined would be appreciated. -
Spray nine. https://www.spraynine.com/
@topgun2Thank Bill. I am guessing it must be the ground wire. Just coincidentally happening when the trailer had shifted while on the tongue jack. I appreciate al the feedback from everyone. DW
@SeaDawgIt shifted when I raised the camper to detach it from the tow vehicle. The camper just moved back a small amount until the tire chuck engaged fully. When it happened the light no longer worked as well (so no power). I removed the cover manually raised the camper and manually lowered it back onto the tow vehicle hitch. Once the weight was off the tongue jack the power instantly came back on. The first time it happened I could not find a reason the power was out (ie: Blown fuse) but it started mysteriously working again after the weight was off of it. Perhaps there is a short somewhere it has only lost power those two times??
This has happened two times to me. Our Ollie had shifted a bit while on the tongue jack and the jack lost power. There must be a sensor in it that cuts off power if there is torque pressure on it.
