cmdmom286 last won the day on February 16 2019
cmdmom286 had the most liked content!
Female
cmdmom286's Achievements
By the way Oliver did not have the size molding I needed. So I contacted the company who manufactures them directly. The are Coutoure located in Florida. Info@countoureusa.com or 888-656-9317.
Called Bulldog customer service. Said that what I am experiencing is not uncommon. Recommended spraying the lever area and the underside of the coupler with WD40.
Thanks to all of you for your suggestions. I am going to call bulldog tomorrow and see what they recommend. I'll let you all know what they say. Am going into my sixth year of camping with my Elite I and have put around 25,000 miles on it.
I am having increasing difficulty with the hitch coupler. It is becoming almost impossible to move the lever to open up/close the hitch. I called Anderson and they told me to contact Oliver. Has anyone else had this issue?
I have an 2018 Elite. The trim/fascia for the microwave sheared apart in the middle on the right side and I need to replace. Any ideas? Don't want my microwave falling out when I am on the road.
Carbon monoxide detector failed
cmdmom286 replied to cmdmom286's topic in Mechanical & Technical Tips
By the way I have a 2018 and there is no fuse, unfortunately. -
Thank you all. Mike did call back and I cut the wires. How hard is it to install a new one? -
I have a call into Mike, but in the meantime one of you all may know the answer. My carbon monixide detector has failed. I have tried repeatedly to reset and get the beeping every 30 seconds. It went bad on the way home from Montana. I just picked it up to go on a road trip and of course it is still beeping. I called the manufactuer as listed in the Oliver manual and was advised it is no longer made or available. I just want to turn if off. There is nothing in the manual about turning it off, only installation instructions and testing. I look at the fuses and don't think it has a dedicated fuse. Any ideas how to turn if off? I have a portable detector that I will be using. I just cannot tolerate that beeping every 30 seconds 24 hours a day. Thank you in advance.
I have and use the travel valet (5000 lb). By the way the smaller one will not work on the Ollie because it needs to be used from the side. I store my Oliver in a warehouse and there is not enough room to back it in with my vehicle. I bought it on eBay for $100 less than a used one (with the same new product warranty). It is easy to use and I cannot imagine being able to back it in and out of the space without it. Hated to spend $750 but allows me to handle camper easily by myself.
I am now the proud owner of a Legacy Elite!
cmdmom286 replied to cmdmom286's topic in Introduce Yourself
Just finished my maiden voyage of 24 days and 2000 miles in my Elite. Had several issues but had a great time! Saw lots of Utah and fished Utah, New Mexico and of course the Colorado. Boondocked at Canyonlands and Escalante. Still afraid of the water system so using water from five gallon container. Having issues determining how much water is in the tank. When I initially added water from my home it gushed out from underneath the camper. I don't know if I haven't closed a valve properly or what. Am configured properly for water though. Weathered a blizzard in Bryce with 60 mph winds and whiteout, and even drove across the pass towards Cedar City Utah with no issues. Easier to pull and maneuver than I thought. Oh and I caught a 24" Rainbow on the San Juan. Life is good! -
Had the same problem. That is why I am sideways in my picture. Tried everything and gave up.
Also do you have to buy a pump to push in the bleach/ off site water? And one final question. Filled the tank with water to start the bleach process. I know it is filled because water running out from under the camper. I have tested releasing the water through gray valve after running the pink stuff out of the faucets and no water will come out. I am on a slight incline on my driveway. Is this the reason or is it because the gray tank is not full? Thanks again for advice. -
New question. Getting ready to head to Utah and dewinterizing the camper. Don't know how to oven hot water valve. The photo says in front of the heater but that is flush against the side of the interior wall and I cannot see anything. Thank you for helping me out. -
Thank you! A relief! -
So many questions. Thank you for all your advice and recommendations. Here is my latest issue. Today I moved my Elite into indoor storage. I have read the manuals about the batteries and it might as well be written in Russian. Here is my question. Where I have it stored there is only the standard three plug 20amp plug, no 30 amp. Could I buy two trickle chargers and hook each battery separately up to one of the chargers? I really don't want to or have the confidence to physically remove batteries or disconnect them.
