Gliddenwoods Posted March 17, 2024 Posted March 17, 2024 My Xantrex Freedom X Pro inverter displayvpanel is flashing (20)!. We are plugged into the campsite 120/30 amp post and all trailer systems are operating OK. Frig on AC and 120 outlets work. Why the flashing code? No 20 error code on page 389 manual. Thoughts? 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
aaronorange Posted March 17, 2024 Posted March 17, 2024 Check this link https://support.olivertraveltrailers.com/portal/en/kb/articles/xantrex-inverter-error-20 Hull #1238 - 2022 Legacy Elite II, TB, TV 2017 Tundra TRD.
aaronorange Posted March 17, 2024 Posted March 17, 2024 I had this problem several times. After I reset the breaker located in the space under the bed near the inverter. I then change the setting in the Xantrex app "Breaker Rating" to 15A . I was plugged into a household 20A receptacle and I think that may have had something to do with it. Good Luck. Check this link https://support.olivertraveltrailers.com/portal/en/kb/articles/xantrex-inverter-error-20 1 Hull #1238 - 2022 Legacy Elite II, TB, TV 2017 Tundra TRD.
Gliddenwoods Posted March 17, 2024 Author Posted March 17, 2024 Thanks...will try. 1 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Rolind Posted March 17, 2024 Posted March 17, 2024 I only had this problem at one campground. It happened repeatedly throughout the weekend and never since. Later when reviewing the campground info it seemed to imply it only had 20 amp service on the 30 amp side. I didn’t think that was possible, but the error never happened again at any other campgrounds. Interestingly I’m headed back there in a month and will see what happens. 1 Robert and Cheryl, Louisville, KY, Legacy Elite II 2023 Hull #1390 Oliphino, TV F250 Tremor
Gliddenwoods Posted March 18, 2024 Author Posted March 18, 2024 Arronorange....followed the instructions and all is well now. Thanks again. 3 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
