Boudicca908 Posted July 18, 2024 Posted July 18, 2024 I have been in contact with OTT Service department recently, to ensure that I have my Xantrex settings correct, before I test out using a small generator that was given to me. I plan to post a separate thread about the generator, but during this conversation with OTT Service, we were unable to find the definition of a setting labeled "nAt". Anyone know what it stands for? For reference, here is my description of it and the OTT Service response. Apparently it's not a setting that can be set via the Xantrex bluetooth app, but has to be done by using the Xantrex Panel. That is a process that I have not succeeded doing yet, as I get lost in the endless codes and can't seem to follow them from one screen to the next, book in hand. MY QUESTION TO OTT SERVICE: Checking through my Xantrex Settings, I noticed the following settings on MY XANTREX APP are different from the "normal recommended" settings in the Knowledge Base article. (The Xantrex App doesn't provide the setting #, only the setting name; I've tried to insert the setting #s here for clarification). INVERTER (heading on app) #13 Inverter Shutdown Recovery -- mine is set at Manual Restart. In MY MANUAL for 2022 Elite 2 components, the default setting reads "Manual -- Man". On the app, my Xantrex is set to "Manual". BUT on the OTT Knowledge base it says the setting should be "nAt" and I don't find that defined anywhere ... I am still not sure what this setting should be. OTT SERVICE RESPONSE: I cannot find a definition of that abbreviation but this is the setting that would need to be changed through the panel. I want to note that OTT Service department has been extremely helpful to me. Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
Ronbrink Posted July 19, 2024 Posted July 19, 2024 (edited) nAt is manual restart. This default value is the recommended setting for #13. The following may be helpful either to you and/or others. Sent to me by Oliver at my request. Edited July 19, 2024 by Ronbrink 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ronbrink Posted July 19, 2024 Posted July 19, 2024 22 hours ago, Boudicca908 said: Apparently it's not a setting that can be set via the Xantrex bluetooth app, but has to be done by using the Xantrex Panel. That is a process that I have not succeeded doing yet, as I get lost in the endless codes and can't seem to follow them from one screen to the next, book in hand. This explains the process in using the remote wall panel to change the Xantrex settings. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Boudicca908 Posted July 19, 2024 Author Posted July 19, 2024 6 hours ago, Ronbrink said: This explains the process in using the remote wall panel to change the Xantrex settings. I've done that a few times, and get lost in looking for the setting number. j Do you see that the nAt means "Manual Restart" -- and on the Xantrex App it uses the abbreviation "Man" for Manual Restart. So my conclusion is that I CAN use the Xantrex bluetooth app and that mine is set correctly. I think this confusion is due to Xantrex not correlating their abbreviations from the panel to the app. THANK YOU for finding this. I will share with Mike at OTT Service. 1 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
Ronbrink Posted July 19, 2024 Posted July 19, 2024 (edited) 13 hours ago, Boudicca908 said: on the Xantrex App it uses the abbreviation "Man" for Manual Restart My Xantrex 2000 is not BT capable, but find using the remote panel easy to pan through the settings and make changes. I obtained the settings table from Oliver when converting to LFPs; only difference in my specific settings were #9 set to 2.0 (inverter is 2000W [2.0] rather than 3000W [3.0]) and #24 set to 80 (2000W inverter/80A charger rather than 3000W/150A charger). Edited July 20, 2024 by Ronbrink 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
