Cindy Townsend Posted September 1, 2024 Posted September 1, 2024 Any idea how to fix this pull if it pulled all the way out today for some reason? Scott & Cindy - NC & MI 2024 Ollie LEII, Hull #1454. Better known as Pearl Lithium Pro Package (390AH, 400W Solar, 3000W Pro Inverter), Truma water heater TV: Ford F150 Hybrid
Moderators mossemi Posted September 1, 2024 Moderators Posted September 1, 2024 I am going to have to make some assumptions with the limited information you have provided. I am also going to ask some questions so I can try to help. 1. Did the pull/push handle stay attached to the stainless steel wire? 2. Did the SS wire pull all of the way out out the black sleeve? 3. Do you know where the grey tank valve is located? 4. Do you have a twin or full size bed? 5. Do you know how to access the area below the street side bed and front dinette? Mossey 6 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Moderators Mike and Carol Posted September 1, 2024 Moderators Posted September 1, 2024 Mossey asks all the right questions. If the cable is no longer attached to the valve it is probably just a matter of pushing the handle all the way in and then loosen the set screw on top of the valve, reinsert the cable and tighten it down. I’ve pulled both the black and gray cables all the way out from cleaning and lubing. They easily insert back into the sleeve to the valve. Then it’s just a matter of putting the cable under the set screw and tighten it down. Mike 7 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Moderators mossemi Posted September 1, 2024 Moderators Posted September 1, 2024 I spoke to Cindy and her husband and they will give our suggestions a try. Mossey 7 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
