Duplex Posted September 5, 2024 Posted September 5, 2024 Has anyone had an issue with the CO2 monitor alarm sounding as the ZAMP charge controller is starting as the sun is rising? At least once a week while hooked up to shore power, our CO2 alarm sounds and flashes the Low battery code. The ZAMP rep says "if the CO2 monitor is not isolated from the solar system, this could mean a short or crosswire situation." Any help would be appreciated, we would rather not be awaken by flashing light and an alarm. This usually happens while the ZAMP controller is flashing as the sun is coming up. Does your ZAMP controller flash as it is starting each morning? Thanks, John
Ronbrink Posted September 9, 2024 Posted September 9, 2024 You may want to present your question in Mechanical & Technical Tips of the forum for a better chance of response. 3 2020 OLEll, Twin, 579: No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, Hughes Autoformer, dual Lagun tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, Dreiha Atmos 4.4 A/C upgrade. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Buyers Products cargo containment boxes/DC Cargo securement system; pending transfer of DC-DC cable run and Mechman 320A high output alternator from former TV.
Moderator+ ScubaRx Posted September 19, 2024 Moderator+ Posted September 19, 2024 On 9/5/2024 at 2:55 PM, Duplex said: Has anyone had an issue with the CO2 monitor alarm sounding as the ZAMP charge controller is starting as the sun is rising? At least once a week while hooked up to shore power, our CO2 alarm sounds and flashes the Low battery code. The ZAMP rep says "if the CO2 monitor is not isolated from the solar system, this could mean a short or crosswire situation." Any help would be appreciated, we would rather not be awaken by flashing light and an alarm. This usually happens while the ZAMP controller is flashing as the sun is coming up. Does your ZAMP controller flash as it is starting each morning? Thanks, John What the Zamp representative is says is that the CO monitor should be hooked directly to power (like a positive buss bar) to isolate it from all other systems. 1 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
