Steve Morris Posted April 22, 2025 Posted April 22, 2025 My latest project. The weather hasn’t cooperated enough to get time to get much done before heading to Alabama, but I’ve made a start. 12V DC and 115V AC outlets hidden behind the drop down table. Not wired yet, so I’ll see if I can get that done. Im still planning on a 12V DC Anderson outlet down low on the front of the propane cover for the truck fridge, and a 115V AC outlet on the street side But those will be after the rally. I definitely need the 12V before an eight day no services outing in the Adirondacks in June Stop and see us in Curiosity on site G23 4 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Tideline77 Posted April 23, 2025 Posted April 23, 2025 (edited) Would you mind explaining the Andersen truck fridge wiring plan ? I would like to wrap my head around how that will function Thanks Edited April 23, 2025 by Tideline77 Robert E 2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
Ronbrink Posted April 23, 2025 Posted April 23, 2025 13 hours ago, Steve Morris said: Im still planning on a 12V DC Anderson outlet down low on the front of the propane cover for the truck fridge, I don’t recall Anderson offering a water tight 12v outlet for smaller connections. You could run the fridge wire inside the cover from the bottom where any connection within would be better protected when underway in inclement weather. Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Steve Morris Posted April 23, 2025 Author Posted April 23, 2025 (edited) 14 hours ago, Tideline77 said: Would you mind explaining the Andersen truck fridge wiring plan ? I would like to wrap my head around how that will function Robert, I currently power the National Luna fridge in the back of my Land Cruiser using a Bluetti E70 power station. The CD power connection for the fridge is an Anderson Powerpole plug, and I use an adapter to go from the other end of that power line to the cigarette outlet on the Bluetti. This setup works great for short trips, or longer ones where I can plug into AC at a camp site and use the AC power port on the fridge. But when half the fridge is set to freezer, I only get about 24 hours out of it before the fridge shuts down from low power. Solar helps, but in June in the Adirondacks we will be in full shade for 6-8 days. So I need to use the Oliver's 640 A/h of power, instead. As a temporary fix, I use an Anderson to Anderson extension cord, the Anderson to cigarette adaptor, and a cigarette outlet to alligator clip adaptor directly to the batteries on the trailer. Quite a Mickey Mouse setup, and prone to poor connections. As a permanent fix, I will remove the front tray and drill a hole in the front of the propane housing, and install an Anderson Powerpole outlet. I will tie into the existing front jack's constant 12V DC with a fused line to the new outlet. Then I can power the fridge directly from that outlet using the Anderson to Anderson extension cord I already have. This will also work if the Bluetti is low when parked overnight, such as at a Cracker Barrel. Of course the best fix would be to put solar on the roof of the Land Cruiser, and install a large LiFeP04 battery in there with all the associated bits, for a much longer power reserve. But I already have the huge battery bank in the trailer, and this little project is just a few dollars instead of hundreds for adding power in the truck, let alone eating away at the cargo capacity and volume of the truck. Hopefully, that answered your question. Edited April 23, 2025 by Steve Morris 3 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Steve Morris Posted April 23, 2025 Author Posted April 23, 2025 2 hours ago, Ronbrink said: I don’t recall Anderson offering a water tight 12v outlet for smaller connections. You could run the fridge wire inside the cover from the bottom where any connection within would be better protected when underway in inclement weather. Ron, I have the linked PowerWerx outlet with cover. This, and having the front tray directly in front of the outlet will protect it during travel. For static use, I'm not too concerned about moisture problems. I know of many off-roaders that have uncapped large Anderson outlets that see extremes of water and mud without problems. I'll use heat-shrink and liquid electrical tape on the back side. https://www.amazon.com/Powerwerx-PanelPole1-White-Anderson-Powerpole-Connector/dp/B097QDRCZ4/?_encoding=UTF8&pd_rd_w=S89In&content-id=amzn1.sym.255b3518-6e7f-495c-8611-30a58648072e%3Aamzn1.symc.a68f4ca3-28dc-4388-a2cf-24672c480d8f&pf_rd_p=255b3518-6e7f-495c-8611-30a58648072e&pf_rd_r=HFMQYHNB03JBF42Z0SQ0&pd_rd_wg=y6sNl&pd_rd_r=56524771-83d9-4578-ad45-7bab707b31a6&ref_=pd_hp_d_atf_ci_mcx_mr_ca_hp_atf_d 1 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Ronbrink Posted April 23, 2025 Posted April 23, 2025 32 minutes ago, Steve Morris said: I'm not too concerned about moisture problems. Understood, I’m one to fully protect important outlets, especially with my fridge. Potential power disruptions from a wet/compromised 12v circuit is hard on a compressor and the unit in general IMO. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ronbrink Posted April 24, 2025 Posted April 24, 2025 On 4/22/2025 at 8:49 PM, Tideline77 said: Would you mind explaining the Andersen truck fridge wiring plan ? I would like to wrap my head around how that will function Thanks The above response to your question from @Steve Morris is a very practical approach to ensuring adequate power to a TV-staged fridge/freezer unit, especially taking into account longer run durations with use of the OTT’s battery bank. My approach was somewhat similar, however my former TV had a 200W solar array atop the bed cap for the specific purpose of helping to keep a homemade 100Ah LFP power station sufficiently charged for extended use. I can get 33 hours of continuous run time on the PS alone, and as much as 48 hours when the solar input was optimum. But at some point the PS would need a supplemental charge and thus, an AC powered battery charger came into play either upon reaching a campsite with shore power or via the OTT’s inverter power. I installed a forward-facing AC outlet on the propane tank housing for the same purpose @Steve Morris plans to install a 12v Anderson, but in my setup I utilize the inverter when underway to supply AC power to my Dometic CFX 75DZ, as needed. Since I have yet to install solar on my current TV, supplemental charging of the PS is provided via an extension cord from said outlet into the van to power a Victron 30A Smart charger connected to the PS. Although this setup works great when the Oliver is in tow, pending install of solar on the van rooftop is needed for other lengthy travel times or when venturing away from camp and AC power is unavailable for supplemental charging. Remote charging of PS: 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
