Chris and Lisa Posted September 27, 2025 Posted September 27, 2025 Hello from Oliver Elite 2, 2022 Hull 1191. We have water leaking out of the bilge through the drain holes when the water pump is on and the line is under pressure. My husband would like to access the water line under the shower. How is this done. Chris and Lisa 2022 Oliver Elite II; Hull #1191; TV-2019 Toyota Tundra Other Trailer: Camp-Inn 550 Teardrop
jd1923 Posted September 27, 2025 Posted September 27, 2025 1 hour ago, Chris and Lisa said: We have water leaking out of the bilge through the drain holes when the water pump is on and the line is under pressure. My husband would like to access the water line under the shower. How is this done. When your Oliver is perfectly level, which side is the water leaking from? "Under the shower?" Do you mean in the wet bath? The water lines are in the bathroom vanity. The front cover with the opening and towel bars must be removed. Outdoor shower? Access the water lines under the streetside bed. Ours was leaking once when I left the outdoor shower faucets on. Only the valve on the shower head was holding the water. Check first that these faucets are OFF. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Ronbrink Posted September 29, 2025 Posted September 29, 2025 I suggest you move your inquiry to the ‘General Discussion’ section of this forum for better chance of viewing and response. Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
jd1923 Posted September 30, 2025 Posted September 30, 2025 (edited) 17 hours ago, Ronbrink said: I suggest you move your inquiry to the ‘General Discussion’ section of this forum for better chance of viewing Yes, and given a water leak, they ask for help, and it’s another few days… Edited September 30, 2025 by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
