Hello from
Oliver Elite 2, 2022 Hull 1191.
We have water leaking out of the bilge through the drain holes when the water pump is on and the line is under pressure.
My husband would like to access the water line under the shower. How is this done.
IMG_7587.thumb.jpeg.9d23e68fdc70876ef18c60e9b8a62fb8.jpegChris and Lisa
2022 Oliver Elite II; Hull #1191; TV-2019 Toyota Tundra
Other Trailer: Camp-Inn 550 Teardrop
1 hour ago, Chris and Lisa said:
We have water leaking out of the bilge through the drain holes when the water pump is on and the line is under pressure. My husband would like to access the water line under the shower. How is this done.
When your Oliver is perfectly level, which side is the water leaking from?
"Under the shower?" Do you mean in the wet bath? The water lines are in the bathroom vanity. The front cover with the opening and towel bars must be removed. Outdoor shower? Access the water lines under the streetside bed.
Ours was leaking once when I left the outdoor shower faucets on. Only the valve on the shower head was holding the water. Check first that these faucets are OFF.
I suggest you move your inquiry to the ‘General Discussion’ section of this forum for better chance of viewing and response.
Yes, and given a water leak, they ask for help, and it’s another few days…
Edited by jd1923
