Townesw Posted September 30, 2025 Posted September 30, 2025 Is anyone using the new Dill Bluetooth TPMS? If so, how do you like it? I’ve been using a Dill TPMS since early 2019 and I really like it. I don’t want a system that uses externally mounted sensors on the valve stems. It’s time to replace the sensors mounted inside the tire and I see that Dill has a new Bluetooth version available without the dash or windshield mounted display. https://www.dillvalves.com/product_cpt/1604-v-bluetooth-aftermarket-tpms/ Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax
jd1923 Posted September 30, 2025 Posted September 30, 2025 3 hours ago, Townesw said: I don’t want a system that uses externally mounted sensors on the valve stems. I fully agree with your statement. I'm also interested in these but have no experience. Bluetooth, do they have an app to read tire PSI and temps? 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Townesw Posted October 1, 2025 Author Posted October 1, 2025 (edited) 19 hours ago, jd1923 said: Bluetooth, do they have an app to read tire PSI and temps? @jd1923Yes Sir, the app displays pressure and temperature. I really like the Dill system but I want to do away with the windshield display. I’ve been studying the internet and my truck’s RPO codes trying to come up with a way to display the trailer sensor feedback on my 2019 (built August 2018) Duramax Infotainment System. I have the I06 radio and the Z82 towing package but I don’t have the additional RPO’s to do what I want to do. Some information online says that you can’t add the stuff I need but I’ve come across discussions in forums that say that you can add add stuff after production. Edited October 1, 2025 by Townesw 1 Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax
jd1923 Posted October 1, 2025 Posted October 1, 2025 4 hours ago, Townesw said: Some information online says that you can’t add the stuff I need but I’ve come across discussions in forums that say that you can add add stuff after production. There are always some that say you can't do stuff when often you can. I would search the GM/Chevrolet and Duramax forums. Also, Dill tech support may know something. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
